By installing a wide band and using the same stock servo apply pin, should my clearance have changed from disassemnbly?
What I am asking is before dis-assembly I measured the movement of the cover and it took .100" before I could not move the output shaft in one direction (the other moved freely).
Someone posted a while back that there is a direct correlation btw the band clearance and the cover movement.
Now it only takes .005" before I cannot move the output shaft in the one direction. Do I have something wrong here?
Paul
Paul
