Stock Turbo Boost Varies With Air Temp
mingram
I,ve noticed that my boost will vary from day to day according to the air temp. I,m currently using a RJC boost controller which seems to work pretty good. The turbo is in good shape, no shaft end play. I,ts just that some days I cannot get over 20lbs of boost even if I disconnect the wastegate actuator. Is this problem characteristic of a stock turbo?
Thanks Mike Ingram
Eric Marshall 108 chip programed for 22lbs, K&N replacement filter, 160 thermostat, 340 Walbro hot wired, AFP regulator (43lbs), aftermarket a pillar boost gage, BFG street radials, open dump, PS air bag, blocked plenum heat, OTC 2000 used as a live knock gage, 83,000 mile car, best time 12.57 @ 107.40.
