Yes!
block will need clearance, around the oil gallery, pre assemble couple rod/pistons and see what I mean,
also check crank to piston skirt clearance, again pre assemble and check.
AND......... if you run a big cam, check crank/rod to cam lobe clearance
it is NOT a bolt in deal,
but it IS well worth the hassle,
good luck
