bison - i agree 9's should be doable on the setup as is atleast low 10's, and yes the video's show a pretty solid hook and go from both angles. I should get those hosted. I think one of my problems was that this 200-4r had a transbrake installed the way its set up i have no 1st gear because the 1st gear spot is the transbrake spot. When i shifted off the TB it shifts 1-2 on its own and wasn't revving 1st past 4500 rpm, i then shift into 3rd and actually i shifted a tad late and it hit the rev limiter.
The car only got down the track about 10 times totall and the first 5 wern't exactly balls out, they were pretty much make sure car doesn't flip and burn runs. I got the car as 1/2 a project car and some of the stuff the previous owner (project starter) did wern't what i would call safe. So precautions had to be taken.
