took my motor to weber to get a short block rebuild. balance and reassemble with steel caps and roller cam install well it turns out my speed pro pistons are binding in pins which is a typical problem and the crank needed cut. well with the cost of diamond pistons rings and getting the crank cut i am only looking at $1000 more to just get an all forged rotating assembly which will eliminate 20 year old crank and rods plus give me the strength. well now i have another dilemma with another $500 for the purchase of a balancer and flexplate i can get a stroker kit. IS THIS A NO BRAINER? yes money is an issue but the extra $500 would be a major power increase over standard. WHAT GAINS DOES A STROKER GIVE ON THESE V6'S
