SignUp Now!Ok let's take a standard stroke motor verses a stroker motor. Everything else equal. Piston bore, cam, heads, same tune, ect. How much more hp are we going to see. I know there is a calulator somewhere but can't find it.
I doubt you will see any peak power difference with a 3 bolt setup on a 3.8. You should have more torque at lower rpm's from the added ci but thats about it. The tune and cam would likely not be the same either. With a 4 bolt setup and a solid cam there is a lot more to be gained.
You gain tons of torque and in my opinion, torque with a car that hooks is king on the street!!! My stroker setup has paid for itself a few times over (if ya know what I mean $$$$$).
I agree guys. Torque isn't much if you can't hook. How many of us hook on the street? I have the full rear set up. HR, Mickey T's, ect. I'm not hooking on the street....no way. I keep the car detuned. On the track yes I can put it to the ground. Why spend the extra money for a stroker if your mostly street car? Big bucks for small gains(if you aren't going to finish the package) isn't very good use of the green backs!
Bison thanks the cam kdk is putting in is 218-218 roller if i choose to go the stroker route. Im just seeing if i should spend the extra $5500
For cheap extra HP I would build a 4.1
The extra $5000 would get you alot of supporting parts for your engine. I started this thread to get an idea of the hp increases also. Been studing this for so time. Big bucks for the stroker with all the goodies. For the track I think it is the only way to fly. For the street? Overkill. I've about decided to forget the stroker. I dont see the track enough to justify the build.
The stroker engine also allows you to run less converter then a stock stroke. To run a 66-67mm journal bearing turbo with a stock stroke would need a 3600 or bigger. With a stroker, 3200-3300. On the street, that is much friendlier to drive. Am I correct on this Bison??? This is the info I got from PTE.
Coach
Now that was funnybut once I get on the gas my friends faces go... Mainly because they all have chevy 496ci or 502ci and they keep telling me I wasted my money on my GN.
