HELP: stumbling or detonating?
HELP, I posted this on the hot-air section:
Here's what happend and is happening. On Sunday afternoon, I ported and installed a turbo exhaust compressor elbow from an 86/87 GN. Noticibly the wastegate puck arm is a little taller and I had to lengthen the actuator rod to make up for its height. I had the wastegate set to 15psi before the mod. after installing the elbow, I took the car out and blasted it on the road, even with the rod lengthend, I hit 20psi!!!
Drove the car back home, nothing wrong with the car. Next morning, on my way to work, I had a slight stumble, just as the car was going into 4th gear OD at about 2000rpm, during regular traffic. I thought nothing of it. going back home, it did the same thing, but it wasnt a constant thing. This morning, it started stumbling more as I drove off. It wouldnt stumble if I got on the gas hard, and on the freeway, it started stumbling really bad at 2000rpm on the freeway coasting on 4th gear OD. One other thing, I ran xylene on Saterday for the 1st time. I had about 1/2 tank of 92 and poured in 4 gallons of xylene and 4oz of Marvel's Mystery Oil. The car ran really good on it when I raced this past weekend, though, I was thinking it was a bad mixture at the end. I'm going to refill my tank with 92 this afternoon to dilute the 92/xylene mixture. The only thing I could think of of this happening was my sparkplug wires might've been knocked loose while I was taking off the old elbow or during installing the new one, or I have a fouled plug. I'm going lengthen the rod more to see if things change. I don't know, but what I might think is stumbling, could be detonation
any suggestions or ideas will be greatly appreciated.
Thanks,
Turtle
Thanks,
Turtle
