Stumble off idle
1fastcobra
Just finished my new setup
In my tta.
Front mount
80's
210-215 roller
1.7 rockers
Ported heads 175-155 valves
Ported intake
6776 turbo
3600 stall
70mm t.body & house
Car starts and runs good
Problem is when I snap the throttle at idle Under the hood quick
It Boggs a bit ( like the old quadraboggs ) then it catches it self
Looking for ideas on something to try
Blms are a bit high 141
Not the timing gears the cam sensor. It needs to be set 25 degrees after TDC on the #1 cylinder compression stroke. I've seen people mistakenly install them 25 degrees after TDC on the exhaust stroke. When this happens the fuel injector sequence is wrong.
Neal
I marked the balancer
May be a brain fart on my part
I've built over 30 of these motors only one I've ever had that issue with
Verify fp is rising when the throttle is hit.
Ls1 maf ( switched it out twice ) no change
42-43-44-45 no change
Yes it raises. ( i run twin pumps )
I found it oil pump! !
Can't turn it. Pulled the cam sensor to reset it found this
Time for a new
Cam
Cam sensor gear
Front cover. F------k
Cam sensor
Damm I'm glad I keep extra parts around. $50 bucks all fixed. Blms at 130.
No stumble.
