suggest a boost controller
Tom Tom Turbo
Turbo Goes Woo Woo
I'm stuck as to what boost controller will work best for me. I've got a 6262 turbo and 3" external gate downpipe from Full Throttle. I'd like to be able to easily adjust boost from 18-19lbs to 22-24lbs without a ton of guess work.
Will a manual controller work just fine or should I look to electronics?
manual controllers work pretty well for the dual port gates.
I would start there.
B
I have a PTE 6776BB and Turbonetics Evolution wastegate. With the stock turbo I was using a wastegate controller with a knob. When I installed the 6776 I was getting horrible boost spike (like 25#s plus instantly). So I removed the controller and I'm running off the wastegate spring. I was still getting some spiking so I installed an RJC boost controller. Goes between the bottom port of the WG and the turbo. Works great. Keeps it at a steady 18#s and is easy to adjust. Well spent 50 bucks if u ask me.
Dan
