I was wondering if anyone could shed some light on corner weight percents, the spring rate they use, shock length and preload they use on their coil over setups.
I will be running AFCO coil over mounted off the axle, but trying to set some background info.
Some people say that the only job springs have are to keep the body up, and that the shocks do the most work when it comes to hard launches. Other say that springs and preload can help out with dialing in a suspension setup.
Hopefully this will be helpful for more than just me.
Adrian
Adrian
