dank GN
BlackArts Automotive (661)993-8277
- Jan 11, 2009
So I almost have everything to do the swap . I just received the cam from Bo at boost crew . It’s all ready and machined for a gear drive . I still need to ether get a new bigger 4 bolt turbo or swap my CT43 6871 to a 4 bolt housing. The headers will place my turbo forward facing so a new down pipe will also have to be fabricated. I also have 2 intake manifolds . One of them is from a indy car but this one is the only ones I have ever seen that has individual throttle bodies. It also has rectangular ports for regular stage heads not square indy ports . The big hurdle with this intake is it was ment to go on a short deck indy block so I would need to make some spacers to make it work with a regular hight stage block .
