T64E, Front Mount, 65lb Injectors, Acufab 70mm Plenum/TB/Power Plate
MidGaGN
The "Computer Guy"
Returning the car back to stock, the performance stuff has to go...
T64E Turbo
P-Trim/Big Shaft
3" Inlet / 2.5 Out
ZERO shaft play
I suggest a 3400-3600 stall
$550 Shipped
4" Front Mount and Pipes
I was able to add 3 extra lbs of boost and my intake temps dropped significantly.
Used a Fbody radiator mod and the car never went above 190 in this Georgia heat.
$450 Shipped
I have some flow matched 60lb injectors that have only have 5000 miles on them. Also a TT street chip comes with them.
I can get the pictures if needed - $275 shipped
Finally I have a polished Acufab 70mm Throttle Body, Plenum and Power Plate.
This has literally 500 miles on it.
This also comes with an angled IAC boss that is polished as well.
$450 Shipped
I've been watching this section for an Intercooler for a couple of months. No luck so I bought a new one. Now there have been several offered. Isn't that the way it always works. :rolleyes:
What made you decide to go back to stock if you don't mind me asking?
~JM~
~JM~
me too...
2nd in line for injectors
Hey guys, im converting it back to stock hoping it will sale better.
Spooled is next on the injectors if the first buyer doesn't want them...
I believe that the T64E is Precision's version of the Limit Engineering TE-45A. I just thought I would mention that because the TE-45A has a pretty big following and has been proven over and over again as a solid 10 second performer and some of the newer guys might not realize this is the same turbo with a different name. This turbo offers a lot of performance for the price being asked!
why is one of the lines on your vacume block , blocked off? and is that a stainless steel line on one of them also..?? why is that?
It isn't stainless line, it's a rubber line with a stainless clamp. I don't need that port so I blocked it off. All of my EGR stuff is removed off of the car...
Thanks for the info Steve! I didn't even know that myself.. I just knew that it's pretty crazy on the top end..
Intercooler and TB/Plenum sold...
Several people want the injectors, the first to paypal $275 get them shipped to their door...
To help sale the turbo, I'm also including the turbo blanket (paid $100 new) I have for free.
Turbo and Injectors still for sale....Turbo $500 shipped (add $20 if shipped to Canada) and $250 for the injectors ($260 shipped to Canada)
