SignUp Now!I bought this turbo from Percision ,dyno time only. Short version, is waste gate hole large enough, 15/16 ? It has Garrett .63 housing.
I,m not going to scare Cal Hartline, just don,t want issues boost creep.
and i dont get the advice about it being ok for moderate boost
moderate boost (low boost for 91-93octane ) is usually only obtainable with a proper fitting puck to the watgate port
, if the puck is too large compared to the hole (more than 1/8 larger than the hole ) then it could impede the air flow out of the wastegate hole and the result would be poor boost control - higher boost at higher airflow (rpm) , if your goal is high boost (running race fuel or alky inj) leave it alone unless you find you cant maintain the boost level you intend to run without it creeping upat the top end of the gears , if you port it you may find boost will be lower than you want with a std wastegate and then have to go to a HD gate to just get to those higher boost levels, and if you port it and go too far leaving a gap when puck is closed then spoolup will suffer
in your case the houstons pucks are larger than stock but 15/16 is already a little bit larger hole than stock puck would have (stock is 1-1/8") so i wouldnt touch it .
and its either a TA49 or a TE44 , both use the same wheels but the TA49 looks like stock turbo outside , the precision (not percision) is a TE44 and has an integral inlet in the compressor cover and as far as performance the TE44 compressor cover is good for about 20-30 hp over the similar wheeled TA49, the TE44 is commonly equipped with a .82 exhaust housing and the TA49 with the .63 , but there are .63 te44's and .82 TA49's
Some time ago I talked to reps. at Percision and Limit. One or the other told me that TE44 was with actuator, TA44 was Without with act. or other way around. Hope you hair hafers are satidfied. To those who were very helpful THANKS.
Smaller than it needs to be . Its small enough so that the factory puck would seal on it if it had to. Id guess smaller than .900in.Well where are you hair hafers when I need you? What is the "stock" size of waste gate hole on TE/TA/ TEC/ TAC44 ETC?
