TA6262 CEA vs TE60
Howling Mad
Just wondering if any one has tryed the TA6262 and if is worth $400 more in power and spool with champion irons 206/206 roller and 2800 stall PTC lu converter. Any info would be great.
The 6262 will support a lot more power. The te60 will spool faster. You are already over cammed for a turbo with a small stage 3 turbine like a Te60. The 6262 will overpower your converter once you make enough power to go over 120mph in the quarter.
Probably wont see the track too much just a fun street car, but low 11s high 10s. Ill be putting alky on it when I get around to it.
6262 but not the ta version
With the converter you have there is. If it was a 9.5" it would be less noticeable
