tach wiring
dav770431
Tyler
which of the two wires on the green connector in front of the water pump do i splice my aftermarket tach wire too?
does that come out of the plastic harness holder that bolts to the valve cover or from a different one?
What kind of tach? Usually its ground for one. Red fir 12 volt ignition and the tach signal to the Green connector by alternator. Some You have to cut brown wire fir 6 cylinder
the tach wire from behind the valve cover goes to the tachometer input on dakota dash harness on lower right. then go to setup option and put in the info
