I was underneath the car today and discovered that there is a lot of play in the tranny's tailshaft. If I have this much play how much damage have I done internally? And what needs to be done?( Aside from the tailshaft slop, the tranny shifts perfectly.)
Paul
1972 Toyota Celica with a 87 TR drive train.
PTE 44 turbo @ 20psi on pump gas. Jay Jackson’s 62 mm throttle body, ported and polished plenum and intercooler. Solid MAF pipe, K&N Filter. Blue tops. Hot wired 255 L/hr Holley inline FP., AFR. AC CR43’s. Type II coil pack and module. 8.5 Magnecor’s. Hand made TH style DP, 3” exhaust split to two 2 ½ inch Magnaflows.
Built 200 4R tranny, B&M cooler, stock D5 converter, B&M Megashifter.
Chopped Ford 9” four link setup @3:25 posi rear with a 300 ZX disk brake setup. Air bags, Bilstein Rally shocks.
85 Supra 57 mm piston 10” vented rotor front brake setup. Hurst Roll control. Tokico race struts, heavy duty coils. Nissan 300 ZX 15/16 master cylinder.
Dunlop SP 5000 205/50ZR 15’s, Ford power steering rack.
DirectScan, Caspers Knock gauge, Autometer 30/30 boost/vacuum gauge, Autometer tranny temp gauge. Jay C’s 94, Red’s 100, Thrasher 92, and my own chips
Paul
