I didn't get a chance to comment much on the data yesterday....
If you compare the Turbo PSI to the MAP PSI its 23.0 vs 21.7 at the end of the run, a difference of 1.3 psi. Looking at the average data for the whole pull I am losing about 1.5psi boost from the outlet of the turbo to the map sensor in the plenum. So this is for the IC plus all the pipes etc. Not very much at all. Ideally I would compare just pre and post IC boost but this is still very good data to know. I wonder how much is through the IC itself and how much is from all the pipes, etc. It would be great to compare to a dutt neck stock IC that is common for stock setups to see what the pressure loss is and if it stays constant throughout a pull and at different levels of boost.
The other great data is the delta EGT temp pre IC vs post IC. I'm cooling down 208 degrees through the FMIC at the end of the pull based on the different EGT temps between EGT #8 and #7. As a doublecheck, I can get a close calculation to what increase in air temps I should be seeing from my turbo using calculations from here:
http://www.gnttype.org/techarea/turbo/turboflow.html. At 70 degree air temp and 23psi and 70% efficiency it says I should be seeing about 292 degrees out of my turbo, or an increase of 222 degrees over ambient out of my turbo. My FMIC is cooling the air down 208 degrees based on the EGT difference, meaning the air coming out of the IC should be only 14 degrees hotter than ambient, or around 84 degrees. If you add 30 degrees to my EGT readings all the numbers seem to agree.
What I take from this is that my IC is doing a good job. And its a starting point to compare if I make any changes like different boost, different weather, etc. Also would be great to compare to other ICs and turbos.
It also tells me that based on my inlet air temp of 69 degrees in the plenum, my alky benefit is probably mainly as a fuel and in cylinder cooling and octane versus cooling the air charge. On a stock IC I assume the air would be a lot hotter coming out of the IC and the air charge cooling of alky would play a lot larger role.
