TexasT
Texas, Where are you from
- Sep 10, 2002
Did you balance that rotating assembly while you had the heads off? Get it to zero deck? or is this more of a "see what can be done with the factory stuff as supplied"?
If you are at 3200# mid 11s should be easy on a good sixty and good weather.
Probably been twenty five yrs but There was a Guy named David(cant remember his last name, it is hell getting old) from N Dallas out at the motor plex running 11.70s @115-117mph with stock turbo, fmic, chip and a cone filter. Skinny fronts and 28" slicks I believe.
Ken White will go faster. His Limited is pretty heavy.
I'm subscribed. I'm thinking you can go real low 11s maybe teens with the mods. I'm thinking tall tire and 3.23 to load up that turbo(just something to try). Keep plenty of fuel and with the alky stuff these days might be done on some 93 pump gas.
