TE-64E, is it the same as a TE-45A?
Steve
I think I read somewhere that a TE-64E is the same as a TE-45a only from a different manufacturer with a different name but I am not sure. I think the TE-45a's came from Limit Engineering/John Craig and PTE had a version of the same turbo but they used a different name and I think it was either TE-63E or TE-64E. Thanks for the help.
Steve
Steve
The TE-45a is more like a TE-66 turbo in size.
Here is a link where it is discussed.
http://www.turbobuick.com/forums/turbos-turbo-related-parts/88447-big-turbo-stock-motor.html
te45-a is a 66 mm
te45 is a 63mm
t64-e is a 64mm
all use a to4b p trim exhaust wheel
thanks
Bill
T64E used a 66mm inducer compressor wheel, with a P-trim turbine wheel. It had a E compressor cover and came standard with .63 A/R Precision turbine housing. It was rated to support 700 flywheel hp when maxed out.
HTH
Patrick
