Te45a
Royal-T-Ltd
How does a TE45A compare to a 60-1? What is the compressor wheel size and exducer size?:confused:
The TE45A uses the same size wheels as a T66. They have a 66mm compressor wheel and a p-trim exhaust wheel.
Im all over the place. Mostly between U.City and North County. Where are you at?
thats cool. Maybe we can meet at the track one day. Private message me. Hows your car running?
which wheel the te45a uses depends on vintage. the newer ones are 67mm gt compressor wheels. They have a dual 'layer' of fins on the compressor. I sent my turbo back to be upgraded after it happened (never mounted on the car, so sorry no before/after). Yes, the old ones are 66mm compressors. standard is p-trim but I'm pretty sure a q trim will fit. I don't know if you run into any surge that way though.
