my mods are listed!! i am having car worked on and it wont smoke the tires like it use to with a te-61? what else do i need to do to make it run! it feels like it might need more fuel! i am getting lots of knock as well!! all done on 112 octane! boost was set at 26 but spike to 30!!
SUSPENSION,rear
kirban rear seat X braces
right side air bag
southside boxed lower contro arms
FRONT
90/10 drag shocks
new coil's and bushing's
transmission
non lock up convertor ART CARR 1960 9 inch
3500 stall
shift kit.tranny built for non lock up
alco red eagle band upgraded
exhaust
cat back flowmaster 40 series mufflers
no cats
3 inch ATR SS D/P wit open dump tube attached
applied technoliges adjustable wastegate!!
casper's heated O2 sensor
fuel system
fuel pump hotwired
red's XP pump
fuel pressure regulator adjustable
009 42.5 fuel injector's
ignition
casper coil pack
casper volt booster
red's spark plug wires
colder plugs autolight 124
motor
bigger valve springs!!!
turbo
TE61 port and polish biger shaft wheel told equal to a TE64..with a .63 exhaust housing
intercooler
stretch 21 row tony dequick
odd's n end's
scanmaster 2,1
boost guage
oil pressure guage
water temp gauge
VDO RPM guage
145 mph speedo overlay recalibrated
engine tie down
160-t stat
KN cone air filter
chip
a RED 110 chip
SUSPENSION,rear
right side air bag
FRONT
90/10 drag shocks
transmission
3500 stall
exhaust
no cats
fuel system
fuel pump hotwired
red's XP pump
ignition
casper coil pack
casper volt booster
motor
turbo
intercooler
odd's n end's
scanmaster 2,1
boost guage
oil pressure guage
water temp gauge
VDO RPM guage
engine tie down
160-t stat
KN cone air filter
chip
a RED 110 chip
