Team Banana
- Aug 9, 2008
SignUp Now!Brp solid mounts. They wanted them forward an inch farther than I put them. I had to drill some new holes and welded them to the frame.What motor mounts you using?
These are as close to the firewall as you can get and as low as you can go without interfering with the steering linkage to oil pan. Kevin B has some so you might PM himThanks just trying to figure out which mounts to use i want it closer to the firewall and low in the cradle.
