SignUp Now!Stock fan. Runs on high only though. It doesn't sit exactly flush against the radiator. Maybe a half inch gap. Could that have that much effect on it?
In a prior post you said you removed the stat. Now you say you have a 160 stat. If you do indeed have a 160 stat then maybe your stat is stuck closed.I got an aluminum radiator from advance for 54.31 using an online coupon code. Lifetime warranty. Fits perfect. Only problem is, I'm still running hot. Only when I have to stop and go. Fan runs on high only, rmi25 and waterwetter, 160 stat. Temps get up to 200 and what concerns me is my oil press goes from 22 lbs at 170 degrees to 12 psi at 200 and I shut the car down so I don't know how high it would have gone.
