SignUp Now!Can you rent those vacuum setups from the parts store?
Sounds like the radiator is stopped up and not flowing as the theromostat is removed , fans may help but I doubt it .Today I removed the t-stat and for about 5 min it stayed about 167, which is when the fans are set to come on. After that it kept climbing higher and higher as I drove around the neighborhood and when I finally pulled In the driveway it was 192. Tomorrow I will check on the intrepid fans at the local junkyard.
Radiator is new. When cap is off I can see a nice stream flowing before I topped it off. Don't think radiator is stopped up. I'm gonna try fans and if that doesn't work I'm ordering a champion all aluminum 3 row for a camaro. I'm just not spending 500 dollars on a radiator.
local parts store F-body will be the best bang for the buck...........
