UnderdogGN
- Oct 18, 2004
hi, i need some help with my cars new studdering problem. It started right after i put a new alky kit on it. It only happens when you ease into the gas, gradually building boost from around 3lbs on up. If you go WOT there is no problem. Also, the faster you are going when you ease into the throttle, the faster the bucking will start. Like if im going 65 in O.D. the bucking will start at 1lb of boost. And it does it in every gear except 1st. I dont think it is the alcohol doing it because the alky turns on at 9lbs. In need some serious help here!! This is getting really annoying.
thanks in advance
thanks in advance
