I know they've recently updated the Blues material wise.
Bruce uses them IIRC.
I started using the HE frictions because GM came out with them to help with the 3-4 clutch pack in the 4L60s. I'm sure they spent some time developing them, and they work well. The builders who have been doing the trial and error method on these units with the limited friction and apply area have had good success using the HE's there. If they'll work in that application and live better than the Red's and as well as or better than the Z-Pak, they have to be a decent material.
I talk to a few noted builders frequently and many say the reds simply don't hold up in the 3-4 of the 700/4L60. They definitely don't hold up using th Alto Power pack with it's thin steels, but don't seem to work as well even with thick steels, as the HE's.
That is interesting to me, because they seem to work great in the directs of as 200-4R, Th350, and in the past the TH400 for me.
I had a TH350 several years ago...
Tightening the last pump bolt and it twisted off. Weak fatigued bolt, late night thrash, twisted off even with the case.
I pulled the pump to look at the bolt, re-inserted it to use the pump as a guide to drill the bolt, and in and out a couple of times more, plus final assembly.
It had iron sealing rings on it.
After 9 months of operation one of the iron sealing rings broke. I am certain from a fracture of multiple pump R&Rs.
The trans was running Reds throughout.
Forward clutches lost pressure on the way home from the track according to my friend, he baby'd the car home from stoplight to stoplight and it made it.
He brought the trans to me, we ripped into it, and of course had to replace the pump, forward drum due to scoring from the failed iron ring, and I installed new frictions in the FWDs, but the steels were COOKED. The Reds were actually in pretty decent shape. They had obviously seen some heat, and were "browned" but they were not black, or seperating, etc. They actually looked really intact and almost re-usable. Normally with the way the steels looked, the friction lining would have been seperated from the metal backing or completely gone and in the pan.
That's my experience with the Reds and it was convincing enough that I believe it to be a good material.
I have a 200-4R in the shop from a GN, high 10 second car IIRC, I'm warrantying it for an odd issue with fwd drum eating up the center support. Looks like a lack of lube flow at that location only. CS and bushings are toasted. Fwd drum sealing rings torn, clutches failed.
All the rest of the frictions look NEW. Directs looked great, band looks like I installed it yesterday, etc. Not too bad for a "weak" transmission
