think about what your asking.the only problem would be increased heat at hiway speeds because of the lack of converter coupling and the increase in rpm needed to maintain a given road speed.lock up 400 is only available thru precision industries,we do make one for the th350 with a brake and lockup.you can also attach a gv to it if you like.however with the avaiability of our new GMAODE WITH LOCK UP the 350 is probably going to be a second choice to most.Isaw you had a link to fbperformance as well.he is making something similar as well,but unfortunately he copies everyone elses tech and generates his own versions.very ugly and his aod valve bodies are crude copies of
'LENTECH" originals
STAGE 2 TH350 TRANSMISSION
The Stage 1 TH350 transmission is built for heavy duty towing,street/strip and limited drag racing vehicles with engines producing up to 750 foot pounds of torque.Each transmission is professionally assembled and then given a thorough road test in our test vehicle to ensure flawless performance prior to shipping.Are you tired of intermediate sprag and outer race failures and the maintenance and downtime they cause?The Stage 2 transmission is assembled with our CNC machined unbreakable oversize 36 element sprag and drum assembly to eliminate sprag failures.Be sure to check out our custom gear ratio and lock up torque converter package under “Optional Equipment”
COMPETITION COMPONENTS
Lightened heavy duty direct clutch drum outfitted with oversize unbreakable 36 element sprag assembly and spiral lock ring.Heat treated intermediate sprag outer race.Heat treated input shaft and drum assembly.Heavy duty sun shell.Oversize direct clutch drum bushing.Sun gear with 4 bushings.Oversize lo roller clutch assembly.Rollerized front and rear planetary gearsets, lo race,sun shell and pump cover.
CLUTCH AND BAND UPGRADES
5 forward,5 direct,5 lo reverse and 3 intermediate red lined clutches.New intermediate band
HYDRAULIC UPGRADES
Increased line and lubriication pressures.Dual feed direct clutch triples clutch apply pressure.Custom calibrated valve body and governer assembly.New factory pan and high flow filter.
#350-2/HDT1 $1149.00 Heavy duty and towing calibration.
#350-2/HDT2 $1249.00 Heavy duty and towing calibration for diesel,turbocharged and supercharged applications which require a mechanical vacuum modulator.
#350-2/MA1 $1149.00
High performance street and strip calibration with manual/automatic valve body.
#350-2/MA2 $1249.00
High performance street and strip calibration with manual/automatic for diesel,turbocharged and supercharged applications which require a mechanical vacuum modulator.
#350-2/FPFM $1199.00 Competition forward pattern full manual valve body.Specify with or without engine braking.
#350-2/RPFM $1399.00
Competition reverse pattern full manual valve body.
#350-2/TB $1549.00
Competition reverse pattern full manual valve body with "Pro Tree" transmission brake.This one of a kind CNC machined transmission brake uses the intermediate clutch pack and lo reverse clutch to apply the brake giving the user the fastest release available.Period.
OPTIONAL EQUIPTMENT
#350LUO Transmission with lock up torque converter $699.00 This option utilizes a torque converter with a lock up clutch.When applied,the clutch eliminates the slippage present in the converters fluid coupling .This allows the flywheel and transmission input shaft to be locked together (rotate at the same rpm)for faster et and mph.
#350GSA 2.70 / 1.52 custom ratio planetary gear set. $449.00
This gear set is used to increase torque multiplication/rotating speed in the transmission in first and second gears. This improves acceleration with heavy vehicles and numerically low final drive ratios. (IE: 3.23, 3.42, 3.73) .
#350BH S.F.I. approved bell housing installed. $349.00
#350TS S.F.I. approved transmission shield. $139.00
#350DS Filler tube and dipstick with locking cap. $55.00
