The great debate Hydro vs Vaccum
Place your vote for the situation that best describes your experience
  • I have vacuum and have NEVER had lack of assist
  • I have vacuum and HAVE had occasional lack of assist
  • I have hydroboost and have NEVER had a problem with assist.
  • I have hydroboost and HAVE had problems with assist (any type of problem)
  • I've got a perfectly fine, working PowerMaster system and don't give a rats ass :)
  • My PowerMaster system sucks, and i've just about crashed my car
Results are only viewable after voting.
My install is finished. Used the 10.75" dual diaphragm (88 Caprice) and matching master. Brake pedal feels great, but the verdict is still out on how i feel about the swap.
The pedal is still stiff on initial application if i quickly go from throttle to brakes, and i feel there is too much assist. Too easy to lock the wheels.
I want to put in some more seat time, as i've only driven a mile or two. But i did make several stops testing things out.
I couldn't find the info i wanted on modifying the stock PM brake pedal, so i documented mine a bit more than what i'd found here to share with those that do this in the future.
Here is a shot showing where to locate the new pin. Drill the hole 28mm below the center of the existing pin. This isn't rocket science, so being a hair off isn't going to effect things.
I used a grade 8, 7/16 'bolt that was about 4" long. This gave me the smooth shoulder that i needed for the rod end out the back of the booster. Cut it off the same length as the existing pin, weld bolt in place, and drill a hole for the new hitch pin/cotter pin, and put a washer at base of the new pin to mimic what the original pin has. ** also as a tip for reinstall, put the bolt at top of pedal back in from the opposite direction than it came out. Make things way easier and no cables or wiring will have to be moved. Putting the nut on the end of the bolt is tricky, but i used the open end of my box end wrench to hold the nut, then taped it in place while i positioned it onto the bolt.
