Boostnitup
- Feb 20, 2002
96 option code - 1984 Grand National
OK another question about my '87 GN (November '86 built). Is it unusual to have the letter "X" as the 9th character in the VIN number? I have read that the X is a "place holder"?
Mine has the 9th character "X"; Another member asked me if this was true a few months back when I first joined the board and posted pics of my car.
Here are a couple pics- the dash VIN plate pic sucks but you can still clearly see the "X" character.
John
You are correct in that it's probably not important but there is a formula for how GM determined the check digit. I'll post it as soon as I can dig it up from my archives. BTW It could also be a letter A through Z minus a few like O,Q and I.All my GM production booklets gives a definition for every other digit 1 thru 8 but nothing for 9 except stating "check digit" the rest being your production sequence.Since no definition is given for the 9th code, it is probably something that is not very important in determining factors about your car.
The tubs of our cars were built by Fisher Body at the Buick City facility in Flint and trucked south down to the Pontiac MI plant for final assembly. This was true for even the Hot Air cars built in Flint although most of the time the Fisher Body facility was in the same plant as the GMAD facility. Fisher built the bodies and GMAD or General Motors Assembly Division did the final assembly. These are evident in the two SPID label codes FFL=Fisher Body Flint and GMD. As far as I know the Pontiac plant was the only G-Body plant that did not have an on site Fisher Body facility. Which is why you don't see the GMD code on any SPID that has the PON code.That code is for the plant it was built in. H in this case means Flint. Most cars at least 1986-1987s and I know 1987s for sure will have a P for Pontiac plant. partially built in Flint that finished up in Pontiac.
You're wording that wrong. It's Regal Limited with a turbo motor. Remember the LC2 was an option and the Limited was a Model. There were 3 Regal models for 84-86. J=Base,K=T-Type,M=Limited. And that's why no K code for 87. Goes back to the argument of why there were no T-Type Regals built in 87.You can see how some of the codes are redundant or don't make sense even to me. My experience is 1987 so its the 1G4GJ for Regal and 1G4GM for Limited model. In 1986 their was no turbo Liimteds so it should read 1G4GK instead of 1G4GJ which is 1987 only for a turbo Regal. K is for 1986.They also used a K for the Turbo Regal for 1984 and 1985 as show in the 1984 trunk ID label above as the 5th digit on the VIN. Why it changed from a K to a J for 1987 I have no idea.
That's the easy way to tell where the car was built. All Flint cars have that label and that sequence. And all Jerusalem built cars have the sequence reading from right to left. That's a joke of course. I could post labels from the other plants but I won't since this is dedicated to TR's.The fun ones are the Mexican ElCaminos. BTW the 84 GN seat code is AQ9.Take note: Notice how on the 1984 ID label they read in alphabetic order going across each line. On the 1987 labels they red DOWN each column. Without seeing 85-86 in front of me not sure which way they run. Plus has 14 columns shown above as opposed to 13 columns 1987 version
Excuse me if I step on your toes Dennis.
Maybe I need to write that book. It's hard reading these posts that are longer than 100 words.
Oh and Brian wants to know what he wins if he posts his SPID label with less than 52 codes?
I'm tired. I'll post a reply to your Methanol car post tomorrow.
Hi Dennis & Turbo Buick Regal Enthusiasts:
I believe the original manufacturer of the power master brake switch was General Electric! :biggrin:
And I am aware of two different reservoirs for the power master brake set-up - the current one and correct one for all Turbo Buick Regal applications which is square and all level at the top where the brake master cylinder lid attaches AND the second type I have seen which would not be correct for a Buick Turbo Regal application is one that was commonly found on the Buick Roadmaster and large stationwagons of the period where the master cylinder reservoir was on a angle (tilted)...not sure why it was tilted though?![]()
Do I win a bag of M&M's or something? heheJust kidding!
Both my '87 cars have GMD and PON and FFL codes.![]()
WE4 and a GN.
I think the '86's may have one less code out of the 3.
But have others '87's don't.
But we'll never know going about it this way.![]()
Thanks, it must have been a very nice looking car when it was new.
