kirban 2 cents worth
tell brian contest open to running cars with label attached not open to companies or employees magic number is to hit 50 or 100 in other direction.
on the methanol cars like to see how close the VINS are to each other may be similar to the trooper cars I mentioned earlier.
Dennis The car is running with 52 trunk codes with 6 or 7 options. Fully Buick Documented & car faxed. It is actually my test vehicle with our first stretch IC,Down pipe,Aluminum Rad, Spohn's first rear sway bar,level 1's rear arms, 16 x 10 GTA wheels, etc...Typical average T running around with 100K+ miles stock D-5,Stock injectors, & stock turbo. I thought it would be close to 50 but was 52. It is just one of those light weight good running cars you get out of every 40-50. Sort of a freak![]()
I have another car in the lot out front which should be less codes. Not running. I have the top end pulled off but that is something we can get running in a few hours. Same color as the 1 above & similar options. I know it should have less. I have known the car for 7 years finally got it picked up 2 years ago down here.Original paint car as well.
Believe me I wouldn't let employee Magic happen to prove it could be done. I'm a show me person.
When I get a chance to breathe around here during the day instead of walking around with a phone attached to my head I'll sneak a peak at the spid.
I also have a few Moon roof limiteds that should be pretty hi optioned as well.
Close to 100, Yes running.
In my opinion (Mine only) any Turbo car running or not that was produced with an original label should be eligable. I don't think it takes alot to make a car not running to running & driving. If it was Built & totalled & not worth putting back together it exsists. I have a few cars here that are not worth rebuilding for re-sale at this time. Then I have cars I'm upside down in & will not get what I have into them for years.
Heres a pic of an 87 T with 52.
