The Numbers Game with the (SPI) Trunk ID Label - Kirban
kirban 2 cents worth
New Buick Turbo Trivia contest:
No past winners or Buick Turbo employees can participate.
Prize value $50
I have a 700 mile original GN sitting in my garage to verify everything.
Earlier in this thread, we asked to give us a count and name the various filters/screens etc you would find under the hood of a original 1986-1987 Turbo Regal.
This question is similar in nature.
Only this time I want you to list every paper like decal/sticker that can be found on an original 1987 Turbo Regal brand new (not a GNX) that is found under the hood.
Nothing on the suspension counts.
No paper stickers on any WIRE looms counts. Example, the two wire looms on the drivers side inner fender.
We will not count the battery since I can't recall how many seperate labels are on the original white sided battery.
Do not count any label that is related to an option, only what would appear on every 1987 Turbo Regal when it left the factory. Example: If a paper decal existed on the cruise bracket it would not count.
I don't need the exact technical name, however, your wording and location has to leave no room for error.
I will post 2 of the answers here to start the contest:
1-coil module date sticker
2-coil module turbo decal
Your entry must include the 1 and 2 that I have listed above and then go 3, 4 etc and so on with your guess along side it.
The first person that can nail down 14 others that match my 14 wins.
This means you need to find 14 others that appear under the hood of an original 1987 Turbo Regal (not a GNX), and not a decal or sticker associated with an option since that would not appear on every example.
This is a paper-like decal that you could remove.
the clock is ticking.....
If your list involves any wrong ones I will simply state the number you have wrong. By that I mean if you have a total of 3 incorrect I will state that. I will not pinpoint which ones are wrong, as that would tip off another player.
denniskirban@yahoo.com
Takes me time to think these up making sure the answers are not found on the internet. If you have a suggestion for a trivia question send me a pm....I don't mind giving someone credit! Less work for me.
Kirban 2 cents worth
Upon further research their is actually 15 more possible not 14 as stated above. So we will give prizes t whoever hits the 14 we are looking for and whoever can find 15. This is in addition to the 2 we already listed.
The clock is ticking....any luck this contest may last me through next week.
Prize value $50
1. coil pack v6 sticker on end of coil
2. coil pack date code sticker
3. egr valve sticker located on top of the valve itself (6016)
4. power master sticker on front of the resoviour (sl)
5. power master sticker located on the side of the resoviour (do not overfill)
6. EST module sticker located on the module itself (hkp)
7. Throttle body sticker thats barcoded locaed under the inlet
8. Barcoded sticker located on the side of the driver's side valve cover
9. mass air sticker located on the underside of mass air near plug (BW)
10. mass air sticker located ont he underside of mass air that's barcoded
11. caution fan sticker located on the rad hold down plate.
12 belt routing sticker located on the rad support on driver's side
13. air cleaner sticker that located on the air cleaner top (ac air filter)
14. A/C sticker located on the a/c compressor
15. A/C charge info sticker located on the heater box
16. Emission's label located on heater box above the A/C charge sticker
17. fan shroud sticker located on the top left of rad fan shroud
18. garret sticker located on the top of I/C
19. I think there is also a sticker if i remember correctly on the wastegate can assembly.
i may have included some extras here for grins :D
good news & bad news
the good news is you scored quite well.
the bad news is this contest was for non previous winners only....
so, what would you think is fair?
There is one on the wastegate....there is also 2 others.....not mentioned in your list.
I am trying to get other winners so it is not the same ones....
I usually do a different one for past winners eg the horse drawn carriage one.
This contest has ended.....
Will work on a new one.....
kirbanperformance.com
sorry
whats the 2 i missed?
I looked at the code, it looked like HO3B, or something like that
To break down the Fisher Body plate based on the H03B code.
H stands for the year 1987, 03 is the month built meaning March, B stands for the week meaning the second week of March 1987. This makes more sense than the very late date you gave before from the door that you claim could possibly be wrong since it was hard to read.
Again this is based on my notes on the break down that I had in my file system.
Like I said a car fax may offer up a date a month or two later, any broadcast sheet from in the seat cushion or door panel would offer more insight.
As stated earlier we do have a winner on the vehicle trivia contest, finally, 1sloGN above send me pm wit your full address. You will get one of the last 12 of the 100 Anniversary GM books published last year. Very informative book covers a lot of old info etc on GM....hope you see this post before Monday as after that I can't ship it until I return from GS Nats.
I almost missed your answer because you put it at the end of another guess.
The correct answer is a horse dawn carriage.....
Now I know what everyone is wondering what tie in is that with our Buicks? Believe it or not there is a link. I won't make it a trivia question as no one would be able to figure it out. However, I can pose another trivia question off the answer to this one that I was not aware of.
Congrads go to 1slgn.....him like several others really kept at it...more history lessons to come.
sorry i didn't realize that i won that one
Thank for the trivia questions as i continue to learn about my gn/tr as it makes me think
sorry
Make you a deal.....
You tell me.....and its worth $25 in prizes....re-read my clues again it may click for you on the other 2.
Member he who puts up the prizes makes the rules....
You may have had one incorrect in your listing no sure though since you did hit the mininum.
kirbanperformance.
Trivia for all past winners and past winners only
Name the one car model, that I am referring to that only offered a turbo option for exactly one year.
Only put one guess in your post!
It must agree with my answer as I have proof on my end as to my answer. Not saying others don't exist, but you got to name the actual model car I know as being correct.
All previous winners can play
Prize value $25
This is as tough as doing the reseach as the books I have written.
20. sticker/band on the wastegate hose assembly that plugs into the solonoid.
21. sticker/band around the shaft of the wastegate rod?
New trivia contest
NO previous winners eligible nor Buick employees.
Its the mid 1990s....you are the original owner of a 1987 Turbo Regal.
What 3 paper decal stickers could possibly be on your car at this point that was not present when your car was new.? Exclude the battery.
This question is tricky. Note how I worded it.
Prize value $50
the clock is ticking........
If you are reading this thread feel free to share with us your trunk ID label or any question you may have about that subject or option related etc. Chances are fairly good I can answer it...correctly.
nope.... on the boost line replacement ones have a sticker on them but I can't recall seeing any remenants on new cars... the 2 you are missing are fairly evident heck they are stil on my 77,000 mile turbo-t....and of course the 700 mile sitting on the lift in my garage...
no doubt you have done your homework however,
Prize value $25
how about a olds jetfire?
Prize value $25
1984 PLYMOUTH Colt ( not the Dodge Colt )
Bryan
Dennis
the only thing else that i can find/think of is the inspected sticker on the end of the radiator tank just below the cap.
i'm still thinking hard :biggrin:
well of course the 2 paper bands located on the headlight harness on the driver side wiring and the band on the cruise control wiring/vac lines(has 5367 on it)
damn labels
