kirban 2 cents worth
Smokin 6 has hit the magic number (50) codes. Send me a pm with your full name & address and you will get $125 worth of prizes. Please answer in a post the following questions if you would:
I assume you realized you had a low optioned car. Did you realize how rare it is to see one with just 50 codes total?
Unusual circumstances when you bought it....did you get it form the original owner and if so why did he order it that way?
I will point out what I see in your codes and photos.....
starting with your engine shot:
no cruise notice the big gap between washer bottle and air filter.
You have my adjustable fuel regulator on the car.
Powermaster has the repro cardone brake bowl...
The vacuum block on top its not ours ours is not finned maybe caspers?
Plug wires are black may be red armstrongs or old atr wires? fit nicely....
Can't see clearly does your car have that long thin chrome across bottom of the outside? I notice the little block emblems on the pillars my car had them.
Now to look at your ID label
You got a posi...so rite away that tells us the readers if the car did not have that code (G80) would drop it to 49 possible.
You got code VK3 front license plate bracket if your car did not have that would drop code total to 48 so 48 codes would be possible.
You got VD6 and VD7 aluminum bumper braces....a good thing...
Can't see your radio but code is UM6 next to the best they had that year which is am/fm cassette with seek & scan auto reverse and clock feature.
UW4 concert sound which is an option if you did not have that feature another code less would drop count now to 47 possible...
llQ white body side mouldings which my car has also if you did not get that would drop another code meaning 46 codes is a possiblity.
Your car has no rear defogger so probably started out as a southern car....did you know where the car came from originally?
Besides no cruise, no 2 speed wipers, and the biggee no tilt column feature!
I am assuming you know most of your codes 4 codes refer to each coil spring front left front rite left rear rite rear, FE3 is a suspension code. GU6 and G87 rear to rear size etc and brake drums, PON is for Pontiac, AR9 is bucket seats, AO1 is tint, etc and so on...
You hit the number we were seeking and by looking at your codes we know 46 is the new low that is possible....but probably not going to happen.
So send me a pm for your prizes.....I knew 50 was out there....glad you came forward....
So, if you ever attend a Buick event....I think you can say without any uncertainity, you have the fewest codes of any turbo regal present.....took 2 months on this thread to find it!
kirbanperformance.com
denniskirban@yahoo.com
My guess you car could have been out the door when new for around $15,800 or $16,200 in that area....
