The official V8 build begins
Gotta love the eye candy. Looks good Louie. All the best with your project.
Thanks Bud!;)
Chevy 2
Its 3.750 stroke-5.7 rod..
The short rod was neccesary so that I could use off the shelf pistons..
Whats involved in the wiring harness upgrade to V8? Is it just reconfiguring the ECU and making a V8 injector harness, or do you got to run a whole new engine harness? This is a good build up thread. I have toyed with the change to V8 a couple times and always wondered whats involved. With all the Chevy guys up here at the track, buying a long block would be alot cheaper then doing a StageII.
In my case I have a FAST stand alone engine harness. I can reuse the V6 injector harness and just add the other 2 plugs and wires and be set. Or i can just buy another injector harness outright. The XFI just has to be switched to the proper config.. Really its going to run just like the stage motor was . Its going to use a crank sensor ..which is going to be the crank trigger and the cam sensor is coming off the magnetic pu in the ditributor.
Your cheap ass will just put 2 new plugs in:biggrin:
Pistons came in today :wink:
Heads and block should be in on Friday. I then have to take a drive to Champion to pick up. Ill post up as soon as i have em..:)
Man at the rate you are going this thing will run by March!
Id like to have it running by my B-day in late March.. Time doesnt seem to be an issue.. but somehow i know money will...
Good luck with it all! I am jealous, similar setup to what I have been dreaming of for years now. I sold my chebbie stuff & holding out for the BB Buick stuff to get going, and the truck load of money to get dropped off :)
If you still have trouble on the rods, check out Welcome to Ohio Crankshaft
might have what you need. Had a booth next to them at PRI show, nice people & nice stuff, also heard good stuff on them over the years. They had a 3.75 stroke 400 main crank 4140 too, which was my plan. I planned on 6" long rods & custom pistons myself, planned on buzzing it up there 8500+ :cool:
Holler if you need suspension help with it too, gonna be a LOT of HP & TQ there ;)
Rockershafts
:cool:
Unfortunately it will be low.. Like 8.8 to 1. I was looking for 9.5 to 1 just coulnt do it with the off the shelf piston and combustion chamber on the brodix head.
GRP alum rods are here !
Now I just need the block :rolleyes:
