5.73 in the 1/8.
28 psi boost.
Same small valve heads.
Same small displacement.
Outdated turbo.
Wrong manifolding.
Wrong cam.
Wrong TC.
Ebp to Ibp ratio: 1.5-1.6:1. More back pressure.
Like I already stated, the less back pressure is helping, but it's not the complete answer in my case.
Hmmm. I didn't see you post it. What was the boost?
Well, not the ones in the Southern Cal area. And I know you've tuned some of them. On top of that, they're all more motor and head than mine, with more properly sized turbos, too.
Yeah, I'd keep the boost secret too.I let you guess, lets see what you think you know.......
1) What does boosted or not boosted have to do with it?
2) Why do they choose to narrow the operating rpm band? We're still talking 1/4 mile run, right?
3) You have a turbo I can borrow?
Don't get me wrong, I think that's great! Why isn't everyone with stock heads and blocks doing the same? That fella is sure showing the rest how to get it done. Good for him. Just a little more work and he should dependably and reliably be in the 8s, no problem. Can't wait to see it. I'm sure it's a street car to boot. The advancements in head gasket design. Amazing.Secret ? what secret Don, ask him.... I brought this up to show you what other people are doing with less, and all you have to say is whats the boost !!!! not that its very impressive that he doesnt run alcohol, that he the doesnt have a stage block, that he is 200# heavier than you, that he doesnt have nitrous, that his turbo is 5 mm smaller than what you had, that his heads are LESS then what you have, and yet he ran the same as you did with a 76 turbo and you had all those things that he didnt have !!!!!!! You asked earlier in this post HAS ANYONE GONE FAST WITH SMALL VALVES the answer is yes with less then you have.......
That's part of the plan, even if it means doing a burnout across the finish line at my home track. Just want to check the fueling. :biggrin:Donnie,
I think you are overthinking the mach number and it's effects in your motor and should try a bigger valve spring on your existing heads. You can change them out without pulling the motor or heads......just put something about twice as big as what you are running now..... and some big pushrods. Then cut the boost up. I bet you will see you don't have the theoretical upper boost limit you think you have now.
Just give it a try....
1) I wish then you could explain my performance when so many others struggle to get close to the same, and not with just 2 more psi boost.I feel the gains seem from any pulse tuning on a boosted car is minimal. You could easily make more power with 2more psi than you can with any sort of header intake design.
You know why they narrow the rpm range through out the run. To hold the motor in it's sweet spot.
You keep bringing the cubic inches into this discussion like your at a disadvantage. Here again is proof of why you can't say a stroker motor will make more power. The ci only effects the rpm range of the engine, not the hp attainable.
2011 NHRA AAA Auto Club Finals John Mihovetz 6.08 236 MPH - YouTube
Stock stroke, stock ci 281ci mod motor. Fastest run under his index in history. There are 500+ ci engine that can't run this fast.
1) ...2) What's creating this sweet spot? Why is this sweet spot so attractive to them that they'd bother with it? Couldn't they just throw some OEM log manifolds on the car and do the same? Why bother?...
Well there you go. Your reading comprehensive skills are off, my boy. Obviously, you missed the whole intention of this project that I started back in the late '90s. Read up on some of my past threads I've started and you might pick up on what my project is all about.I typed out a big long reply, but deleted it. Why bother. You think you've found some magical thing that is earth shattering and we are all too dumb to see it. If it's true, show us data to support it. And no, an 8.80 with a 91mm turbo, 220" and 30 psi boost on alcohol isn't sufficient data to support it. That's not earth shattering or even remotely impressive.
No one is going to convince you that your chasing after minute amounts of power. When it is quite clear to everyone else in this thread that you could be making hundreds more by refining your combiantion instead of chasing after this pulse tuning. Who's opinion do you respect about turbo engine design? Go argue with them about it. Your not impressing anyone but yourself.
