SignUp Now!Fryguy. Have you ever used nitrous to spool a turbo? It's all right if the answer is no. A lot of guys don't use nitrous.
These turbo discussions remind me a lot of camshaft discussions, as we all try to tailor the correct map for a specific application. But then variable valve timing was introduced, and then perfected, changing how we look at camshaft specifications entirely. The same can be said with turbo chargers of course, but has anyone here actually played with a variable turbine geometry turbo like a Holset found on a diesel...?
Fryguy.
edit: You answered it. Good.
Next question.
Given the option of two single turbos and absolutely no concern with how you were going to have to get it spooled up, which would you pick? One that gave you 76% eff. throughout the run, or 65% eff. throughout the run?
Just pretend for the moment that every other factor had been worked out and the only decision you had left in front of you was the two efficiencies. Which one would you pick. Absolutely no concern with how you were going to have to spool it up. Simple question.That's not really how I build cars. I always pick the number I want to run first, then figure out how much power/rpm I will need to run that number. Then I pick the turbo/engine that will make the necessary power/rpm.
I normally build some amount of "scale-ability" into the combination so that I can step up if necessary, but I've been playing with cars for many years and doing it this way seems to make the most sense for me.
Fryguy.
Next question.
Just pretend for a moment that every other factor had been worked out and the only decision you had left in front of you was the two efficiencies. Which one would you pick. Absolutely no concern with how you were going to have to spool it up. Simple question.
We'll talk about scalability with my combination in a moment.That's not really how I build cars. I always pick the number I want to run first, then figure out how much power/rpm I will need to run that number. Then I pick the turbo/engine that will make the necessary power/rpm.
A stupid question? So you totally ignore efficiency? Maybe I was wrong. Maybe you don't know how to read compressor maps.It's a simple question, but a stupid one. I always choose the parts to make the car run the number I need to run, period.
This starts to run into the scalability, as fryguy put it, of my combination.My opinion, 65% would be my pick(for kill setting). This is because you may be running into the surge limit in some of the RPM band. To stay out of surge and maximize the turbo, the right side of the map is where it at. Another way to look at this is when set on kill, you would be at 65%. I would think not to many run there often.
Think about worse case. Regardless of nitrous, you would like to spool as fast as possible and have it somewhat fun to drive, that is if you chose to street drive the car. With good intercooler and running meth, I would think you can give up a lot of that efficiency. If this was the highest pressure ratio you decided to run than I would go smaller. If you decide to push it further than your selection may not be that far off.
Allan G.
I understand that you can't answer simple questions very well.If we were discussing this in person, I could try to speak very slowly. With this being the Internet, I'm hoping you can just re-read what I type if you can't understand it![]()
I race plenty of V8s during my testing at the track. They know they're in for a whoopin' when I come up against them. No rules.
Dusty,... Let me ask you this question. What does class racing have anything to do with this thread?I remember beating plenty of them with a 10.80 daily driver too. What does that have anything to do with this discussion. You should try a heads up class that has no rules and see how you fair. The record for a 6 cylinder with a 91mm on nitrous and 10.5's is probably 7.30. No rules.
