Home brewed? I thought you were a professional!
I'm a professional transmission tech.
I think I did mention in this thread that this was the third build version of my 'first' Buick V6 project. All the custom metal fabrication work; intake manifold, exhaust mainfold, throttle body, timing cover modifications, nitrous injection nozzles, adapting a Milodon geardrive to a TA block, were my first fabrication attempts at such things.
My first attempts at using straight methanol fuel, nitrous oxide injection, of tuning an ECM and dealing with such a complicated mess of electronics.
My first attempt at chassis modification and setup.
My first attempt at using nitrous oxide paired with methanol, none the less.
My first attempt at using engine analyzing software to come up with a workable high performance engine combination using a particular engine component as the main restriction.
My first attempt at assembling a high performance turbocharged engine.
This car of mine has been my big experiment. Certainly not professionally built by a person that has decades of experience behind him in such things.
Although, I should add, the transmission was professionally built. :biggrin:
