I set goals for myself. It is I who I try to impress the most by reaching the goals I set for myself. I will say, I have impressed myself.
Good..... Maybe try keeping it to yourself. Humble pie its whats for breakfast
Nah. That wouldn't be any fun.Good..... Maybe try keeping it to yourself. Humble pie its whats for breakfast
As I've already mentioned, typically you want the ports in an alcohol engine larger than what you'd have in a gasoline engine. The reason for that is the extra volume of fuel that the alcohol engine has to ingest. Over 2 times more fuel. This extra fuel displaces air that would be ingested. Does the temperature of the alcohol/air charge (denser charge) make up for the small ports and the extra amount of fuel that has to pass through the port, displacing much needed intake air? I doubt it.I think it's due to the density of the charge air the motor's ingesting. Between the cooling effects of your intercooler and using alcohol for fuel, that 31 psi of air your motor is ingesting is much denser than what other turbo cars are ingesting at 31 psi. That would also explain why you're able to do it with the small intake valve. Oh and let's not forget you're also shooting a good amount of spray while boosting up, which cools not only the air but also the intake manifold.
Now when you make 1300-1500 HP from a 1.5 liter production block like BMW did back in the 80s, you let us know.
Dang! I like this post. Thanks.In my opinion, I feel that it is the symmetry of your entire setup, meaning everything working in harmony that is giving you your numbers, not just one thing in particular. The nitrous off the line and the size of the turbo is the key though, as the nitrous is helping you to achieve that low sixty foot with such a big turbo, while the sheer size of the turbo, once spooled off the line, being able to carry you through the entire length of the track. The smaller valves are irrelevant in my opinion, as your cam specs, cylinder head flow, stall speed, gearing and tune are apparently on the money. Oh, and let's not forget the driver apparently knowing what he is doing... :wink:
DonWG said:I wonder how fast others have managed to push the Buick V6 with 1.835 and 1.5" valves? How many made it into the 10s? How many made it into the 9s?
Two extra cylinders and more cubes. Not really the best comparison, but still interesting what others are doing with small valves. Thanks for posting.I still don't think the valves are that big of a deal though because peak numbers don't really mean a thing. Although a separate animal, I can tell you that Marty Stromberger ran in the nine's with a set of 991 truck heads that came equipped with 1.72/1.50 in his 350-SBC. He too needed nitrous off the line to get his two turbo's (stock LC2 turbo's) spooled. Pretty cool read for those who are interested, and want to compare...;
1988 Pontiac Firebird - Featured Vehicle - Car Craft Magazine
[video=youtube;P5e2cWmX5Z0]http://www.youtube.com/watch?v=P5e2cWmX5Z0[/video]
DonWG said:Two extra cylinders and more cubes. Not really the best comparison...
One other difference I noticed. It sounds like from the article that he's injecting the nitrous the whole pass. That would definitely make a big difference. Probably why he's not having to use big boost numbers, too.I agree, but it's essentially the very same argument over on some of the other boards. Guys are building SBC's with nothing less than 1.94 intake valves thinking that that is what it will take to run in the nines w/their turbo's, while someone like Marty comes along and runs the same numbers that they are with a much smaller intake valve, with everyone then scratching their heads in confusion not understanding why. Either way, job well done, your Grand National hauls @ss...
DonWG said:What happens to the speed of sound as the density of the air increases?
4timesT said:Now when you make 1300-1500 HP from a 1.5 liter production block like BMW did back in the 80s, you let us know....
So if I'm thinking right about this, as boost pressure is increased the theoretical choke point of the port will be at a slower speed through the port since the speed of sound through the port will now come about at a slower speed.The speed of sound decreases with the increase in density....
If this is true, then for me to increase boost in hopes of drastically increasing performance with these small heads seems to be a bit silly. With each pound of boost increase, I'm compounding the resistance to port flow.So if I'm thinking right about this, as boost pressure is increased the theoretical choke point of the port will be at a slower speed through the port since the speed of sound through the port will now come about at a slower speed.
