Squid4life
Well, considering going up in turbo size, so figured I would look at a higher stall converter as well. Looking at the 67mm turbos (not really necessary now, but will fit the future build) in a ball bearing. Have an old orange stripe converter that was rebuilt by Neal Chance converters a few years ago and it stalls right about 2,800-3,000. Was looking at the ball bearing 67 which seems to need a 3,300-3,500. I would be using a lock up converter, so I guess my question is: is there any drawback going to a ~3,500ish converter, other than additional heat buildup in traffic driving? I have driven a buddies non-lockup 4,000 stall in a Monte SS and think being a NLU it would be a bit much. How do you like a 3,500 LU? Should I go higher "just in case". :biggrin:
