New guy here, well not new but I haven't ever posted before. I'm not new to buicks or turbo cars but this will be my first turbo buick. I used to have a 72 GS clone and a twin turbo 2000 mustang GT street car.
The car: 86 T-type Wh1. I wouldn't be using this car for a sbc build but it's got 174K miles on it and the motor is toast and has been out of the car for at least 5 years. It has t-tops, but I plan to do a full cage, so I'm not real worried about that.
The motor: Me and a friend built this motor almost 6 years ago and it's never been fired. I'll have to go through it because its been sitting so long. I'm sure I'll put new valve springs in it and possibly a new cam because thoughts on turbo cams have been changed quite a bit since then.
Stock 2 bolt 350 block with steel splayed 4 bolt caps, deck plugs and lifter valley vent plugs.
Eagle 4130 3.75" stroke crank
Eagle 5.7 rods w/ L19 bolts
Ross custom pistons 9:1
Brodix Track1 heads from CNC motorsports in FLA I think they flowed 290 @.550" lift
Don't have the exact cam specs, but it's a cam motion hyraulic roller w/ 22?/23? with 0 degrees of overlap and roughly .580 lift.
Vic Jr. intake that I converted to EFI years ago
83lb./hr. siemens injectors
Accufab 75mm mustang TB with an elbow.
Moroso 7qt. pan
Speed-pro bank to bank setup (may send to fast for an update)
Weldon 2025 pump, regulator and Dial-a-flow.
Turbo setup:
Garret Ht3b with ~72mm compressor wheel (because it's reverse rotation, I'm kinda stuck with it until I decide to build new headers.
1 5/8" primaries 2 1/2" cross over built by Travis quillen at young's performance.
Racegate
HKS bov
Custom air to air made from the largest a/a core that spearco offered at the time.
Trans:
th400 for now w/ a brake. I'll probably buy a new PTC converter for it
The T-type is stock right now. I'll have to put a cage in it and new strange brakes all around. Probably 35 spline axles and spool in the stock 8.5 housing with big 9" bearings. Whatever rear suspension is hot right now.
Any input is appreciated on car setup, possible engine changes, or whatever. I'll run the car locally with as big of a MT radial as I can fit under it. Future plans will involve a better block and rotating assy, 98-106 turbo, Water to air cooler behind the dash, Powerglide and a mini tub. But that's way on down the road. I sold my turbo mustang about a year ago and have been without a hot rod since then. I'm itching to get back to the track and have some fun. I think it will run 5.80's when setup right.
Moroso 7qt. pan
Turbo setup:
Racegate
HKS bov
Trans:
