turbov6joe
Signal 1 J-12
- May 22, 2002
My dad's new motor has maybe 1500 street miles and about 15 WOT passes since its rebuild....it's basically a girdled 109 block with OE rods, roller cam, forged pistons, ARP everything, and a 10/10 crank. Just recently he was driving back to his house and noticed his scanmaster was showing knock retard (KR) in the area of 8-14 degrees whenever he was off idle....however his audible knock detector was not going off at all. Anyhow we put the car on stands and noticed that when we reved up the motor we could here an audible metalic knocking sound...kinda like something was loose but NOT like a deep rod knock. AT idle the motor is as quiet as could be and when using a mechanics scope we cannot hear anything out of the ordinary. Now, when we rev it up or blip the throttle at higher RPM's the sound is obvious and loud enough to hear from topside of the engine bay...kinda sounds like a rattle. AT first we thought the sound was coming from the rear of the motor but now think it's coming from the front I climbed under the car and watched the flexplate while my dad was reving the motor up and noticed that it seemed to be moving back and forth quite a bit...maybe 1/2". However, when we took the TC bolts out and pushed it all the way into the tranny we were NOT able to manually move the flexplate back and forth more then just a fuzz....so that kind of ruled out a thrust bearing for now. We also ran the motor with the TC disconnected...the sound is still there. We then took off the serp belt and the sound was still there. We checked for tightness on everthing we could get a wrench on to no avail. We pulled the oil filter off and cut it open to find a significant amount of copper colored metal in the filter's pleats...I'm guessing bearing material there.
Before we go and yank the motor out do any of you have an opinions as to what this sound is or where it could be coming from? Anyone think rod and/or main bearings? The motor is coming out no matter what, we're just looking for a place to direct our attention to.
TIA
TIA
