I need some advice from any tile setters here. I've laid tile in a number of places on concrete floors at my house.
But now I'm going to be tiling a bar counter top that currently has a lamenant top.
My questions are:
1) Should I just peel off the lamenant top and mortar the tile right to the wood under it or do I need to install the cement backer board? I suspect the wood is just partical board.
2) If installing the cement backer board is recommended, do I just screw it to the existing counter top lamenant, or are you supposed to mortar it/glue it to the surface?
I figure I should use the backer board in case any liquid makes it way thru a crack in the grout and makes it to the wood..that would cause expansion and start poping tiles off?
I've never used the backer board before so I'm not sure how to apply it, and the bar top is curved, was planing to tile the edges too so that may be tricky to apply the cement board there too.
Here's the top to tile.
My questions are:
