time and power to expect
BarbeeT
Just starting
with my old set up I ran a 14.0, all stock with adj. wastegate, running about 16 to 17 psi, 2-1/2 straight pipes, tubular upper and lower rear arms. poston headers, and shift kit in trans and electric fans. now I'm rebuilding the motor, 30 over, port-polished heads and intake. 2800 stall, and alcohol injection. just curious on the posssible times and horsepower to expect. thanks.
Nice run for that amount of boost!
What was the MPH (1/8 and 1/4) and 60' time?
A few questions :biggrin:;
Which turbo?
How much boost/timing?
What tires, final gear ratio?
What gas octane with the PAC?
What scantool are you using?
What race weight?
More importantly, what is the goal?
my 1/8 time was 8.9 @ 76 and 1/4 time was 14.0 @ 94. 60 footer is 1.9.
now im planning on using the stock turbo, dont know how much boost or timing? the tires are mickey t 255-60-15, stock 3.42 gears, 93 or higher octane, no scantool and no weight reduction. my goal would be anywhere in the 12's if possible.
