An interesting thing about the differences in the two power curves, the 60', and the affects on converter stall that some may not be grasping.
With the Stage I configuration, and with having the torque curve dropping rather than climbing during the launch, the torque converter stall was decreasing during the launch. With the car gaining speed after coming off the line, you would expect engine rpm to rise, which would help boost to rise quicker also. What I experienced with the Stage I setup was that the rpm would stay flat for the very first part of the launch. Even though you would expect rpm to rise as car speed was increasing, the rpm stayed flat for a short time coming off the starting line.
Using an engine where the torque is increasing after the launch from the starting line, the TC stall speed will also be increasing. There will be a multiplier effect going on during the first part of the launch. Increasing car speed will have engine rpm increasing as you would expect, and with the rising torque curve, TC stall will also be increasing. The result will be a faster ramp up of engine rpm during the first part of the launch which can only help the turbocharger spool up quicker. A faster boost rise curve will only help reinforce and add to the rising torque curve.
This is all due to the fact that a particular torque converter will stall at different engine speeds depending on the engine torque input level.
