I support the use of a front mount for a couple of reasons. FACT; The first "intercooled GN mule" that was used by the "turbo" group was a silver 85 TType with a front mount intercooler. Most front mounts (due to size) have less of a pressure drop across the core than slic's generally. The PTE SLIC is an exception in some comparisons at ~ 1.5 psi pressure drop across the core. My front mount has about 0.7 psi drop across the core. The slic's are trapped in "an oven" or the engine compartment so where does the heat convection from the intercooler go?. Top of the line front mounts go through the traps with air that's ~ 20 degrees above ambient. The best slic that I'm aware of bangs the traps with air about 40 to 50 degrees above ambient. Work can be done to improve an slic's performance. Most slic's have less heatable mass than most front mounts (inspite of the slic crank pulley fan) relative to a short but equal amount of time stopped. The pressure drop across the core is more of a problem than a temperature drop across the core. Air mass is the most important concept. If my induction system causes the turbo to produce air at 25psi and my intake manifold only sees 21 psi then I cause my turbo to do work (which becomes heat) which reduces air density and drives the cylinder charge to knock. Alky sucks up a lot of that heat but is difficult to relate to the gasoline in the chamber. Stoich for gas & alky do not occur at similar ratios, nor are their burn rates the same. However when a calibration is written for a gas & alky car, the air fuel curve has a hook that pulls gasoline out expecting an alky replacement for that area under the curve since the alcohol is also consumed as a fuel. To me that's like pulling the pin on a grenade and not knowing how much time I have before it goes off. Obviously a lot of folks have mastered the art of explosion control (to a point) but I have trouble with the concept. FACT; the first GN mule used a cast iron radiused plumbing elbow from the maintainence stores to connect the turbo to the downpipe. Much less backpressure than the production released elbow from Garrett.
