Stock cam is a great cam and will knock out high 11's or better with ease.
Whats your goal?
Are you wanting to swap a cam in hoping for gains on your current setup?
How fast are you currently running?
Whats your goal?
Are you wanting to swap a cam in hooping gains on your current setup?
206/206 roller is a good choice, however if going for the champion combo, the 212/212 will also work and still be streetable. 60's, unless going to E-85 then you'll want at least 80's. Tuning is your key, no matter what you choose.
7.50 is what you are running now or goal?
What kinda of 60' does the car cut now. Suspension is where you should put your coin IMO FIRST!!! Especially in the 1/8
