TR cam selection
we2man
What would be the best size cam for a ta60 turbo, thdp, duttweiler intercooler and also what size injectors would top it off? thanks!!
Stock or close to stock. Any injector that will support the power you want
Stock cam is a great cam and will knock out high 11's or better with ease.
Whats your goal?
Are you wanting to swap a cam in hoping for gains on your current setup?
How fast are you currently running?
Whats your goal?
Are you wanting to swap a cam in hooping gains on your current setup?
7.50 in the eighth im dying for a set of champion aluminum heads and matching intake. i've heard the 206- camshaft is real good. Is this true?
206/206 roller is a good choice, however if going for the champion combo, the 212/212 will also work and still be streetable. 60's, unless going to E-85 then you'll want at least 80's. Tuning is your key, no matter what you choose.
7.50 is what you are running now or goal?
What kinda of 60' does the car cut now. Suspension is where you should put your coin IMO FIRST!!! Especially in the 1/8
7.50 on slicks with the ta60 42# injectors adj fuel pressure reg, walbro pump and a duttwieler front mount intercooler. not sure about the 60 footer!
