Turbo6Smackdown
- Dec 31, 2005
Are our heads intercooled 109 specific or what. What year range were our heads used thru, and did any other 3.8's use our heads?
SignUp Now!So any heads, off of any buick 3.8, from 79 up, regardless of aspiration eh? I'm assuming this cross fitting of heads ends at 87?
Yes. There may be some fwd that used the 3800 design in the late 80's but i dont think they started till 90 or 91.So 79 to 89, ALL buick 3.8L heads fit. Regardless of aspiration.
Actually cross fitting ends in 89 with the TTA even though they used a different head and exhaust manifold design. You could put the TTA engine in a g body with the early heads and have a slighly higher compression ratio. I had a set of the casting ending in 6293 on a couple engines that worked like a champ.
It should be the other way around i think. Fwd heads on a early rwd. Smaller cc chambers. TTA had a bigger piston dish volume.
