TR6 ignition systems in stock ready to ship
Mike Licht
I was here first
We have a few of the TR6 systems in stock ready to ship, we also have the LS2 coil harnesses, truck coils that go on top, and Magnecor wire sets. This is a high performance high output system with rev limiter and two step built in. Works with any ECU that works with the stock parts. These won't last and there will not be more for a some time.
Mike
This is the best ignition system for our cars point blank.
I'm pretty sure this cuts spark for rev cut vs fuel like the factory. Spark is far superior. Especially when running Alky and you over rev. It's on my to do list
I'm pretty sure this cuts spark for rev cut vs fuel like the factory which is far superior. Especially when running Alky and you over rev. It's on my to do list
Correct.
So it comes with coils and everything you need to install it?
It is the best system out there. Will it make your car faster? Probably not if tuned right in the first place. Will it make it more reliable and race worthy? You bet!
I will be making these as long as you guys want them. But we make them in small batches a couple times a year. (so you need to plan ahead)
Bob
Ok I understand ! Every one knows your a very busy man and we all greatly appreciate what you have done and continue to do for the Buick community God Bless Bob Bailey :-)
Go to the site and check but I don't think so. Trust me though, it doesn't take too many good stoch modules and coils to equal the cost plus the downtime chasing problems. I drive my car a lot so I was using a coil pack every year it seemed and a module every other. It was better when I hotwired the module but it still never ran on lean cruise as well as it does now.
Interested would like to talk to someone about this. Thanks
what about the harness that moves the module to the fendar well and leaves just the coil on the engine?
Caspers can make you that. I used to run it that way but I moved it to the glovebox
Turbobob will u be in bowling green.
