If you want to bring it down to Cincinnati sometime, let me know.
Yeah sure that sounds like a good idea. I'll PM you.
SignUp Now!If you want to bring it down to Cincinnati sometime, let me know.
Extender chip, I thought it was ok to run the commander with the lt1/trans
Why do I need the extender version?
The fuel pressure line off is 45psi with the 237 reg. Do i still need an aftermarket adjustable regular?
How do I post the DS file? I have just says that the file is not valid when I try to post it. The DS is set for 3.42 and 27" tall tires.
Ok I'll take a look at the plugs. I have an ATR adj regulator but it bled down when I put the mighty vac on it. I assumed it was bad since the 237 did not leak down.
"I just noticed my TPS vt it was like 1.88v at 4400 rpm.....now how can that be? TPS will get switched out today!"
B4 you change it, see if it's loose, and/or just out of adjustment. No/low TPS signal, and the fueling is FUBAR!
Do a key on, engine off test of the tps.. thru it's full sweep.
.42/.44 closed, to over 4.2 WFO, with NO erratic signal output during the sweep.
"Should I have a ground strap from the fuel tank to the frame?"
yes. There should be one there, from the factory. It has a "tooth type" gripper on 1 end. That grip slides onto the weld seam flange, and hooks to the inside of the frame, near the bumper shock.
I drill a small hole, OUTSIDE the weld seam, and add my own.
No way, the launch rpms are like 5200 Like I said I don't know what's going on with this car.
With this much slippage--you're NOT going anywhere fast. You apparently have convertor/ tranny probs TOO...
"Took it for a test drive and it's still only acheiving high 50psi Fuel. Also I noticed the O2s were in the low 600s at WOT".
When the 340 was installed, was the pulsator removed, and the hose/clamp setup put in? There could be a leak, with either of these items installed. [More likely with the pulsator.] Maybe time to drop the tank, and verify the hose connection, and the condition of the filter sock.
After looking at the file i know its been said but there is something very wrong with your converter. if you are pushing those rpms through the traps and only trapping 96. The converter is probably a large portion of your problem. Until you fix this you really aren't gonna be able to diagnose and tune the rest of the setup.
