Chris McDade
- Jul 13, 2001
Went to the track last night with my dad's car. We've only had it to the track once since we build the motor about a year ago. 1st time to the track we managed a 11.19@122 with a bad tune and some other new motor problems. That was about 6 months ago.
We get it off the trailer and my dad makes first pass. Easy pass we say foot brake it and watch the wide band. He managed a 11.28@119 running rich. He said he wanted me to make the next pass, so im like OK no problem! We add more boost to the car to lean on it a little. I left on the trans brake @15lbs car lifted the front tire about a foot off the ground and went a 10.96@117 letting off. The wide band sensor went bad and was giving us bad readings. So, we decided to load it on the trailer didn't want to hurt anything. The car 60ft was a 1.59. Not to good. We think the convertor is to loose, so we are going to pull it and send it in to get checked. This should be a 10.50 car when we get it dialed in.
Question for you guys....
The knock sensor is going off on the launch then it stops after the 60ft. Im thinking that the computer is pulling timing out on the launch and that's why the 60fts are not that good.
What do you think?
What do you think?
